Italian GP/DL 125, 150, 200 & Electronic
Need specific detail for a particular model, or just found something strange and interesting and want to know if its original. All attention to detail seekers report here!
Strict no chatter
Re: Italian GP/DL 125, 150, 200 & Electronic
Postby tonytoolbox » Tue Jan 26, 2016 7:28 pm
been down to powder coaters and sampled 9007 it seems to be a tad dark got him to spray some more samples in different shades of silver/grey and left my original hub with him awaiting a call I"ll look at 7035 tomorrow cookie .cheers Tony
tonytoolbox
Postby tonytoolbox » Thu Jan 28, 2016 7:48 pm
been to powder coaters ive seen RAL 7035 way to light in colour ive gone with a powder made by paramount its could delta silver im very pleased with the outcome :D cheers Tony
tonytoolbox
Postby Covboy » Sun Jan 31, 2016 10:11 am
Hi
I have just aquired a 1971 125 dl ...could anyone confirm if this is the correct engine
LIS * 0162XX
Postby TurboTrev » Sun Jan 31, 2016 1:21 pm
Covboy wrote:Hi
LIS * 0162XX
Yes, 125 LI-S * 01XXXX
TurboTrev
Postby Covboy » Sun Jan 31, 2016 1:58 pm
Postby cookieman66 » Sun Jan 31, 2016 10:55 pm
tonytoolbox wrote:been to powder coaters ive seen RAL 7035 way to light in colour ive gone with a powder made by paramount its could delta silver im very pleased with the outcome :D cheers Tony
thanks for that great help .will get down the powder coaters now .Cheers Andy
cookieman66
Postby tonytoolbox » Wed Feb 03, 2016 7:49 pm
hi cookie my mistake its not delta silver its REGAL SILVER sorry for the confusion :oops:
tonytoolbox
Postby Kristof Lammy pie » Fri Feb 19, 2016 11:21 am
Are the rear 'innocenti' frame badges on 1969 dl150's plastic or metal?
And who does good copies
Kris
Kristof Lammy pie
Postby Covboy » Fri Feb 19, 2016 2:35 pm
Hi Kris
The innocent badge on my '71 is metal
Postby Kristof Lammy pie » Fri Feb 19, 2016 2:45 pm
Cheers Steve.
I need to find one of them.
Kristof Lammy pie
Postby humble » Fri Feb 19, 2016 3:06 pm
On my original late 1971 GP150 the rear frame 'Innocenti' badge was plastic....
humble
Postby Kristof Lammy pie » Fri Feb 19, 2016 3:07 pm
Oh lol.
Kristof Lammy pie
Postby Covboy » Fri Feb 19, 2016 3:16 pm
Im presuming mine is original - it seems old and worn!
Postby Kristof Lammy pie » Sat Mar 12, 2016 6:48 pm
I've just acquired what is supposed to be a a dl125 engine also.
Can anyone confirm for me.
LI-S * 002702
Kris
Kristof Lammy pie
Postby nickw » Sun Mar 13, 2016 2:35 pm
Yes according to your number it should be a GP125 around mid 1969. Usually (but not always) will have an engine number a couple of hundred away from the frame number. A couple of hundred can also mean a few hundred and is not an exact science.
nickw
Postby Kristof Lammy pie » Sun Mar 13, 2016 3:31 pm
nickw wrote:Yes according to your number it should be a GP125 around mid 1969. Usually (but not always) will have an engine number a couple of hundred away from the frame number. A couple of hundred can also mean a few hundred and is not an exact science.
That's great, thanks Nick.
Kristof Lammy pie
Postby hullygully » Fri Mar 18, 2016 3:30 pm
Casa do a very good copy, DONT, I REPEAT DONT, get the VE UK version as they are straight & NOT kinked in the middle as per frame!!!!!! :evil:
Postby AlG » Wed Nov 09, 2016 9:14 pm
GP Red - Does anyone have a scanned copy of the article that I recall Adam Winstone and others wrote regarding the different GP Red colours used between 1969 and 1971, covering the 8073, Martian red debate? I recall it was in JetSet, but maybe Scootering?
Many thanks
Al
AlG
Postby TurboTrev » Sun Nov 13, 2016 4:52 pm
AlG wrote:GP Red - Does anyone have a scanned copy of the article that I recall Adam Winstone and others wrote regarding the different GP Red colours used between 1969 and 1971, covering the 8073, Martian red debate? I recall it was in JetSet, but maybe Scootering? Many thanks Al
I haven't got a copy, but if I think it was proved that the solid red GPs were not the same as the red and white GP150s (which probably are 8073). Adam kindly sent me the formula for martian red matched off his? 1970 GP200. If you need it PM me your email and I'll forward it to you.
TurboTrev
Postby Adam_Winstone » Thu Nov 17, 2016 3:03 pm
Not 'proved/proven' (difficult to do) but after much searching we found that EVERY unrestored red GP/DL that we had access to was the same orange-red colour, none of them were 8073 (the colour quoted by most respected documents)... and a Lechler dealer in UK studied an original sample and concluded that it was not, and never had been, 8073.
We cannot state with 100% certainty that not a single GP/DL ever left the factory in 8073, just that it is highly unlikely. The error simply seems to be an admin error, which once put into print has been repeated over and over again.
Adam
Return to Anorak's Corner
