1955 Model D150 Version 2 - Legshields
Postby Big Al » Mon Feb 08, 2016 6:32 pm
My legshields have sustained some damage on both sides, where the horizontal outer edge starts to turn upwards towards the handlebars, and will need to be panel beaten. ( I am not totally sure that they are the original Innocenti legshields.)
Does anyone have a side view close-up photo of the genuine legshields, which I could compare with mine please, so that I can achieve the correct profile?
Big Al
Re: 1955 Model D150 Version 2 - Legshields
Postby Steve J » Wed Feb 10, 2016 11:13 am
The original legshields for a Mk2 LD will have the plastic shield badge on the left-hand side, secured with two screws. Around the outline of the badge, the panelwork is pressed out to give a raised section in the shape of the badge. I'll try & get some photos......
Steve J
Postby Big Al » Wed Feb 10, 2016 2:24 pm
Thanks Steve, but mine is a D rather than an LD, so didn't have that shield badge, just the chrome D150 badge on the right (before I took it off).
It's the bottom of the legshields I'm concerned about. I think that there probably should be a smooth curve from the vertical to the horizontal part, from what I can see on distance photos on the web.
A side view close-up photo at the bottom of the legshields would be very helpful, as well as one looking down on that edge, just to the right, and in line with, the bottom edge of the brake pedal cut-out.
Big Al
Postby Steve J » Wed Feb 10, 2016 6:41 pm
Sorry Al, I should read things properly.... :oops:
Anyway, here's a couple of images of the Mk2 LD legshields, showing the curve at the front edge - I believe the D legshields are similar at that point, just narrower overall. The legshields belong to one of my projects, and need a bit of work. Not sure if the ragged holes are due to fitting a crashbar, or maybe the scooter had been shot at.......
http://i423.photobucket.com/albums/pp31 ... kuhpct.jpg
http://i423.photobucket.com/albums/pp31 ... el3lpw.jpg
Steve J
Postby jbcollier » Thu Feb 11, 2016 5:16 am
Bunch of D shots here:
https://jbcollier.smugmug.com/Scooter/
(Scroll down)
Let me know if you need close ups of any particular place. I'm away though, until Tuesday.
jbcollier
Postby Steve J » Thu Feb 11, 2016 9:44 am
John - I don't want to hijack the thread, but what's the carb you are using? SH1/20? SH2/22?
Steve J
Postby jbcollier » Thu Feb 11, 2016 2:43 pm
SH2/24 (from an early 70s Italian dirt bike)
It sits on a custom manifold attached to a Cambridge Lambretta alloy top end kit with a modified Li crank compressing against a re-profiled 125DL head and a one-off pipe.
jbcollier
Postby Steve J » Fri Feb 12, 2016 10:45 am
Thanks for that - FWIW, I ran my LD150 with a SH2/22 (and "reverse-pull" throttle cable) in the early 1970s. Used a heavily modified manifold and ported barrel with redrilled Li150 head. It ran quite well, but had an unhealthy appetite for crankshaft tapers - consumed cranks at the rate of 1 every 1,000 miles..... :cry:
Steve J
Postby jbcollier » Fri Feb 12, 2016 2:13 pm
No problems yet, knock on wood. The crank balance factors is wrong though. It's moderately smooth at idle and low rpm but vibrates something fierce at high rpm.
jbcollier
Postby Big Al » Sat Feb 13, 2016 2:21 pm
Thanks to both of you.
John, do you have a similar photo to the very last one of yours (which shows the rear half), showing the front half from the same angle?
Big Al
Postby jbcollier » Mon Feb 15, 2016 6:29 pm
Not home till Tuesday. Will post a few more photos Wednesday.
jbcollier
Postby Big Al » Wed Feb 17, 2016 7:24 pm
Thanks John.
What colour are your legshields and other bodywork on the Model D painted? Is it the Grigio Chiaro/Light Grey (8012)?
Big Al
Postby jbcollier » Thu Feb 18, 2016 11:10 pm
Paint code sounds about right.
jbcollier
Postby Big Al » Fri Feb 19, 2016 11:02 am
Many thanks, John, for taking the trouble to post those photos for me. Very helpful, and very nice scooter.
It appears there were only two colours used originally on the D150, Sand Beige (8029) and Light Grey (8102). Yours doesn't look beige to me so, if it is a match to an original colour, it looks like the Light Grey.
What was the scooter like when you first owned it? Did you do all the work on it yourself?
Alan
Sussex, England
Big Al
Postby jbcollier » Fri Feb 19, 2016 3:11 pm
I got it as a field bike = very rough shape. It was originally the "Sand Beige" colour but it's not a very attractive colour on the D. I went with the light grey though it was not correct for my 1955 model year. I had a shop do the body work.
jbcollier
Postby Big Al » Sat Feb 20, 2016 11:20 am
I feel the same about the Sand Beige, so I am going to have mine painted Light Grey too - much more attractive.
Big Al
Return to Pre 57
Users browsing this forum: No registered users and 47 guests
