missing lynx wrote:did the back lights work before you put the led one on? it sounds to me that some were in the brake light curcit its earthing out so when you press the peddle it's working like the green wire and diverting all the power to earth
Toddy wrote:Are there three wires coming from the back of the Atomic one like the BGM type as the colours can be confusing have you used the correct earth from the unit ?
Meds wrote:just to confirm
Everything works, you hit the back brake no they all go off
What happenes when you take your foot off the brake, do the lights start to work again?
If so then there's a chance that when you hit the back brake it's back feeding the lighting circuits, so look for a short somewhere or there could be a wire crossed.
I would go back and use the original light unit to check that everything works ok, proving your scooter electrical circuits.
Then wire up the LED light unit one circuit at a time
Brake circuit first & prove everything works
Then wire up the back light circuit and see what happens.
