AF cassette clutch
AF cassette clutch
Postby Jamjo » Sat Jan 16, 2016 8:09 am
Hi , just wondered if anyone had an opinion on the best oils to use with this clutch , a post on FB suggested that the sae30 oils would perform better than the st90 . Or that's what I think they are getting at . Just wondered if anyone had any input or experience of what is the better .
Regards James
Jamjo
Re: AF cassette clutch
Postby bike grim » Sat Jan 16, 2016 1:35 pm
I use 30 in mine with an LTH 7 plate clutch. The plates are apparently Honda CR80 moto X. I remember reading that the a
AF cassette clutch plates are also motorcycle derivative so probably be good to use. I think the best thing to do is ask AF and if you are changing clean the plates off and make sure you don't mix so at least you know what you got in there and whether it's working right.
Postby Dave67 » Sat Jan 16, 2016 8:56 pm
Hi, I'm using SAE 30 Vespa gear oil in my TS1 with AF 6 plate clutch. This was advised by the engine's builder and I've not had any problems
Dave67
Postby bazza3004 » Sun Jan 17, 2016 1:06 pm
Motul 10/30 2t transoil in my AF cassette. No slip or drag on ts230.
bazza3004
Postby Mike Davis » Mon Jan 18, 2016 9:53 pm
Motul 10/30 Multigrade in mine with an AF Race cassette and all my customers as well, in fact no problems with any clutch using it. :D
Mike Davis
Postby Train driver » Sat Jan 23, 2016 11:54 pm
For my 255 lambretta with the AF-race clutch and my 220 polini Vespa with the DRT clutch
Train driver
Users browsing this forum: Google [Bot] and 2 guests
