He insisted on the helmet!
Covboy wrote:Hi kris
No you don't need to reroute the cable. Rimini do a full kit and I'm sure UK suppliers do too
I did the modification and was amazed at the difference it makes. Don't ask me why or how it works, it just does!
Also see stickys book
Kristof Lammy pie wrote:Well it's registered RCA 157B!!
It took about 8 days in total.
Kristof Lammy pie wrote:So after lots of work completed I took the TV for its Mot.
A bit gutted as it failed. :'(
Low reading on the front brake and front headlight too high.
Advisory on notchy steering.
Here it is at the Mot station
So I got home and tried adjusting the headlamp, easier said than done as it was as low as I could get it. So I've had to leave it a little loose so it will point down ish.
The front brake was my fault I avoided taking the front wheel and inboard disc apart for a service and new pads. It only read 90 on the meter. As opposed to a 200 reading on the rear.
So the front wheel is off and the hub is apart.
I've ordered some sintered pads from Scootopia.
Anyone have any advice on getting the best out of inboard disc?
Cheers Kris
Kristof Lammy pie wrote:Yes I'm in Didcot. Mot station is Taylors (old Forge) at Drayton.
Are you local too?
