soullad wrote:Looks fun Dickie
If you fitting a new top end you might need to replace the original head cowling and therefore check clearance on your rear runners under the bridge piece. Also dry build your new floor runner strips as the holes may not line up too.
Keep the pics coming mate ...
DSC_0068_zpsg8poumhj by richardhenderson1968Sweet Jesus that doesn't look like it will be easyAfter the diesel use a blow torch and an impact driver, the type you belt with a hammer
dickie wrote:I reckon you're right Mr warkton but I'm going to give it a go with the expectation that I'll fail.
Oddly (to me anyway), the screws have a philips head so that will help when I inevitably have to drill them out, as the drill tends to self-centre.
Anybody taking bets?
Then I just tapped out what was left.
Warkton Tornado No.1 wrote:Then I just tapped out what was left.
I bet you actually just 'cleaned up' the original M6 holes with a tap to get rid of any debris. Quite satisfying, in a way, ensuring some parts are not wrecked!
I hope you have good screws to use in place of the originals.
DSC_0082_zps7crjaqct by richardhenderson1968
DSC_0086_zpsxlvsvli5 by richardhenderson1968Captain Pugwash wrote:Diamond burr will cut through what's left of the bearing, if you can cut it in two places it should fall out. Dremmel time
DSC_0092_zps0eezdfau by richardhenderson1968
DSCF0276_zpsozubwqbb by richardhenderson1968, on Flickr
DSCF0284_zpszygdvtzm by richardhenderson1968, on Flickr
DSCF0290_zpskiwnqtoh by richardhenderson1968, on Flickr
DSCF0279_zpseavi2cpi by richardhenderson1968
DSCF0277_zpsna3y3lfs by richardhenderson1968
DSCF0286_zps60upyxry by richardhenderson1968, on Flickr
DSCF0287_zps1rbclxy0 by richardhenderson1968, on FlickrWarkton Tornado No.1 wrote:Those Moon craters that are in the 'bottom end' & magneto housing are not going to harm anything. It depends on whether you subscribe to the theory of crankcase compression being best when it is 'high' or 'low' which, in turn, may be influenced by your choice of exhaust.
Warkton Tornado No.1 wrote:Personally, I'd be inclined to dress them a bit as an excuse to lower crankcase compression, especially if you are 'stroking' the crankshaft up to 60 mm or more. That's if you've changed your plans since you showed the dodgy SIL crank bearing journal!
No, it's just that he machines back the first few mm of weld to the factory profile. But you've now got me wondering if I should have got him to leave 3mm extra height as I'm using a 110mm rodWarkton Tornado No.1 wrote:However, I'm intrigued as to the 'step' in the crankcase around the four stud holes & transfers. Have you welded in a packer of some sort, or have I still got double vision?
I don't think it's actually a butt plug, but they do work well in that application.Warkton Tornado No.1 wrote:Excellent work, by the way, as to the weld of the kickstart butt plug hole & the overall finish.
Warkton Tornado No.1 wrote:From what I understand, & I'm probably getting this wrong, the extensive welding has been cut back by a machining process that has replicated the original external process extremely well.
I think you've done something like that......
Wow! Presuming the welding hasn't caused distortion, there must be so many crankcases up & down the country (Ahem!) that are 'fragile' ex-racing blocks ported to the maximum & would benefit from that process if it were available & affordable..
