coaster wrote:You'll need to tell us the rest of the details about your carb first, jetting, slide, needle. if the jetting is about right then setting the mixture screw pretty much follows the pattern for most carbs and you'll end up somewhere between 1.25 and 1.75 turns out. Slightly outside that range is probably ok but too far and you either need to increase or decrease the pilot jet by one size.
Users browsing this forum: No registered users and 24 guests
