Airbox suggestions for a 25mm Dellorto
Postby Kristof Lammy pie » Wed Dec 16, 2015 12:15 pm
Hi.
After a few problems with the Jetex carb on my standard sx200 motor I decided to change it to a 25mm Dellorto phbl kit and a 42mm Ancillotti Scootopia exhaust.
Having bought both I totally overlooked changing the airbox plastic elbow.
Can anyone tell me what filters they recommend for my set up. Ideally I'd like to keep the airbox but not too bothered. If I keep the airbox what filter and bellows should I get.
Ta
Kris
Kristof Lammy pie
Re: Airbox suggestions for a 25mm Dellorto
Postby Mag » Wed Dec 16, 2015 1:51 pm
I run a BGM filter in a modified airbox. I've drilled large hole near the top so they can't be seen for the frame loop and removed the funnel from inside.
Mag
Postby Kristof Lammy pie » Wed Dec 16, 2015 3:53 pm
Does the 25mm Dellorto use a 18-20mm air hose/bellow?
Can anyone tell me?
Ta
Kris
Kristof Lammy pie
Postby Mag » Wed Dec 16, 2015 6:27 pm
you need to GP 20mm hose and Li/SX elbow. The carb sits higher than standard (with the MB manifold it certainly does) so you need the sorter hose and elbow.
Mag
Postby Kristof Lammy pie » Thu Dec 17, 2015 9:15 am
Lovely. Thanks
Kristof Lammy pie
Return to Carburettors
Users browsing this forum: Bing [Bot] and 34 guests
