Captain Pugwash wrote:I don't get it, you take away the heart of the engine the original barrel & piston and head remove the original carb manifold air box and filter then fit a TS1 and most likely have a non standard exhaust crank clutch and whatever else needed updating but can't remove a couple of inches or sheet metal from a panel to fit a filter, most likely because it doesn't "look standard"
kalifornia wrote:Well thanks for your replies guys, whatever your opinion. There is about 10mm of clear space between the PHBH and panel so nowhere near enough for a GP200 elbow (I've already tried). Other than the puddle of oil on the runner board, inside of panel and all over the engine, it's the amount of grit and shit stuck to said oil on the inside of the panel that's scaring me! If it gets that far, at some point it's going in the carb! Seizure City!!!
I dont want to cut my panel because my paint is nice and it'll allow it to start rusting.
According to the LTH website, their extra short TS1 manifold with a Mikuni TMX32 (or 30 I presume?) Will allow the use of a Tino Sacchi rubber elbow and long foam stack filter.
Time to start saving.
kalifornia wrote:I've just searched members for Jimmers and can't find him. Have you got a link or can you point me in the right direction please Toddy? Cheers
kalifornia wrote:Ah, will do. Many thanks. A
BTW, are you the Toddy that built an RB200 motor for John Collins?
Users browsing this forum: Majestic-12 [Bot] and 20 guests
