Donnie wrote:Thanks for the reply Adam, 17/46 and the Franspeed super clubman (whatever that is as I cannot find evidence of these anywhere online and can only assume it relates to the MB Clubby) is what is recommended by Richard Taylor himself for a fast touring setup
Adam_Winstone wrote:If you do go for either of those pipes then keep the 16 tooth sprocket close at hand, with the 15 not far away either. I note that Burnside is using an MB clubman in that link, which will have a very different gearing requirement.
I note that Richard Taylor gives his email address on his home page and asks people to drop him a line if they have any questions, so that would probably be my first move.
If you want to drop the revs and pull a 4th gear ratio then you might want to consider the Franspeed Road pipe, which as the name suggests is a good option for those that want a motor to pull well on the road
Adam
dickie wrote:Donnie wrote:Thanks for the reply Adam, 17/46 and the Franspeed super clubman (whatever that is as I cannot find evidence of these anywhere online and can only assume it relates to the MB Clubby) is what is recommended by Richard Taylor himself for a fast touring setup
The franspeed super clubman (also known as avanti clubman) is a semi mythical beast of Ron moss creation and is currently unavailable. I've pestered him a couple of times for one but he doesn't have any so obviously can't sell me one!
If he gets them I'll be near the front of the queue.
Donnie wrote:Adam_Winstone wrote:If you do go for either of those pipes then keep the 16 tooth sprocket close at hand, with the 15 not far away either. I note that Burnside is using an MB clubman in that link, which will have a very different gearing requirement.
he has the mb on the 200, im assuming that a) it's got a bit more grunt anyway with the extra cc's, but also he may well have a different riding style / use for the 200? I am making an assumption though to be fair.I note that Richard Taylor gives his email address on his home page and asks people to drop him a line if they have any questions, so that would probably be my first move.
I might well do that, im not too near buying a pipe yet to be fair so have a bit of time, which is why i thought i'd do a bit of research here on peoples opinions and thoughts, which are much appreciated.If you want to drop the revs and pull a 4th gear ratio then you might want to consider the Franspeed Road pipe, which as the name suggests is a good option for those that want a motor to pull well on the road
Adam
added to the consideration pile
Users browsing this forum: No registered users and 2 guests
