Covboy wrote:Hi Wack
You suggestion is exactly what I did . I'm really impressed with the kit - I've really enjoyed riding it this year with the GT186 kit - all straight form the box, no problems
viewtopic.php?f=19&t=2333
I'm gonna buy another + the gt crank for my series 2
Eden wrote:Covboy wrote:Hi Eden - that's dissapointing!!!! On that basis I guess mine does about 48mph max!!!![]()
Re gearing - just standard which I think is 15:46
no it was blip.ill find the graph and upload the pic
it does read higher than my gamma but only a couple of mph.
Wack wrote:Have you all gone 58/107 on the crank? What app are you using Covboy?
burnside wrote:Wack wrote:Have you all gone 58/107 on the crank? What app are you using Covboy?
I've got the GT 60/110 crank and using Li150 box 17/46
coaster wrote:burnside wrote:Wack wrote:Have you all gone 58/107 on the crank? What app are you using Covboy?
That would be about 4.6:1? is that a 186 or 200?
burnside wrote:...Yes 4.6. I'm running the same gearing on both my 186 and 200 Colin. Only thing I will say with the 186 and Franspeed Race is that I find I have to change down to 3rd more often to keep it in the power band, whilst I don't have that with the 200 and BGM clubman. But as long as I don't let it drop below 60 it's not an issue
I use strava for walking and cycling and one night I used it to check my Vespa speedo, max speed 77mph![]()
The next morning I had PM's and emails from irate cyclists !!!! Strava had downloaded my results and I had smashed local PB's on a 10k route![]()
All these quick boys wanted me off so they could have their table positions back.
edit. found them.
blip like I said lol
more normal
