salient wrote:I have a Ducati stator from an AF type light flywheel DC system. In this case, the 4 lighting coils are double wired in series with 2 yellow wires at one end connected to each of the double wires and a red wire at the other end connected to both double wires. Can anybody tell me what is the point of this double wiring and how this is wired into the regulator. Seems that AF have not sold this DC system for 20 years and so don't appear to have a wiring diagram. Is this a 50 Watt system? Grateful for any comments please.
I can imagine the output power is dictated by the number of turns and the wire gauge per coil but not sure what double wiring will achieve.
salient wrote:Thanks Captain,
Where does the red wire go which is a shared connection from the two other ends of the four double wound lighting coil? Do you have access to a wiring diagram? On each pole, are there 2 separate windings wound on top of each other? Any idea how much power this stator produces?
salient wrote:I need to get my head round these stator wire issues. When you have a series of lighting coils wired in series and at each end there is a yellow wire, I can see that both these yellows would go to both AC inputs of a 4 bridge rectifier. Presume both yellows will be out of phase.
But when as in above AF DC case there are 2 yellows at one end and a red at the other, I get confused as you say all 3 wires go to rectifier. Both yellows will be in same phase so should I connect them together and then the combined yellow pair forms one input to the AC inputs of a 4 bridge rectifier and the red the other AC input?
salient wrote:OK so where do the 3 wires feed into the rectifier?
