Flywheel holder
Flywheel holder
Postby grandpa » Mon Jun 02, 2014 7:45 pm
Hi Chaps,
A flywheel holder can be made from a section of steel bar 30mm wide and 5mm thick available from hardware stores.Drill two 10mm holes and one 16mm cutout as per picture and use 10mm thread Image
If you remove the thread nearest cut out and file the end of the remaining thread to fit into one of the holes in the clutch spider the cut out will fit on the rear shocker post and you can hold the spider whilst tightening/loosening the spider nut
This was posted on old database .Although the old forum database appears lost the ideas,fixes, pictures of rebuilds and comments are still there on individual member's computers and could be re-inputed to rebuild the database.
This is a start
Grandpa
grandpa
Re: Flywheel holder
Postby Andy-DL » Wed Jun 04, 2014 4:35 pm
Great work Grandpa - thanks!
Andy-DL
Re: Flywheel holder
Postby Phil D » Sun Dec 06, 2015 5:21 pm
When I get chance i'll knock one up . :idea:
Phil D
Re: Flywheel holder
Postby Dimitrios_231 » Sun Dec 06, 2015 8:11 pm
The design looks very practical,
I'll try to make one too.
This is the original workshop tool 58013
Dimitrios_231
Re: Flywheel holder
Postby duncan1958 » Sun Dec 06, 2015 10:20 pm
I can testify that this tool does in fact work very well ,made one last year and has come in very handy
duncan1958
Re: Flywheel holder
Postby coaster » Mon Dec 07, 2015 8:58 am
Brilliantly simple idea, ust be a bit careful with the amount of thread poking into the flywheel as it would be easy to catch the coils
Re: Flywheel holder
Postby Marty ULC » Mon Dec 07, 2015 9:51 am
Does the holder have to be that overall length or would it work okay if it were trimmed just beyond the two threaded bars?
Marty ULC
Re: Flywheel holder
Postby grandpa » Mon Dec 07, 2015 12:35 pm
Marty ULC wrote:Does the holder have to be that overall length or would it work okay if it were trimmed just beyond the two threaded bars?
Hi Marty,
Cant remember why I made it that long as it was posted on old forum but probably made it that long to provide a handle for extra safety.
If you have any of the bar left over you might consider making this:
viewtopic.php?f=10&t=144&p=538&hilit=fork+spring#p538
Grandpa
grandpa
