Old skool Kwaker dampers
Postby Nobby » Sat Dec 05, 2015 12:39 am
How are you fitting these on to the forks people?
Cheers.....
Nobby
Re: Old skool Kwaker dampers
Postby Norrie Bodge » Sat Dec 05, 2015 1:34 am
Norrie Bodge
Postby Nobby » Sat Dec 05, 2015 11:24 am
Ta,so with these the dampers fit below the fork bracket?, what stops these spinning round tho ??
Nobby
Postby Warkton Tornado No.1 » Sat Dec 05, 2015 2:20 pm
I believe that the subject of Kawasaki steering dampers has been covered many times & for good reason. However, you may be unaware that they ruin the handling of a front damper equipped fork.
With suspension, the spring is there to take any shock load & damping is required mostly for rebound to control oscillation that may otherwise occur, hardly any for 'dive' or compression.
Steering dampers won't provide those requirements as they are consistent in both directions.
Postby Nobby » Sat Dec 05, 2015 2:54 pm
Warkton Tornado No.1 wrote:I believe that the subject of Kawasaki steering dampers has been covered many times & for good reason. However, you may be unaware that they ruin the handling of a front damper equipped fork.
Yeah know all of that (after being on lcgb forum for 15 years) and don't care! - I'm building an old skool 80s custom (viewtopic.php?f=19&t=3225) and want it to look right and ride old skool ( hundreds of scooter boys covered thousands and thousands of miles on this set up back in the day), I have bgms on my s1, standard innocenti on my sx200 and nothing on my 150 special but I need kwaker dampers on bla
Nobby
Postby LateAgain » Sun Dec 06, 2015 8:59 am
:D
Roadrunner got Kwakers on Nobster. I'll take a pic later.
LateAgain
Postby Nobby » Sun Dec 06, 2015 2:51 pm
^cool!
I mean just bolting them to the bracket is the easiest way but makes them spaced away from the forks to much imo, and it would be nice to use the top rubber mounts to....
Nobby
Postby gaz_powell » Sun Dec 06, 2015 4:07 pm
you can use a thread bar connector (a long nut !)
you keep the top bush that comes with the damper - screw the extended nut onto it then insert it into the damper bracket on the fork leg, drill through a 6.5mm hole to allow you to bolt through (in the normal way)
hope that makes sense
Gaz
Postby Nobby » Sun Dec 06, 2015 5:11 pm
I got you gaz!, I know exactly the threaded bar connectors your on about...... Hum ok will make something next week I reckon....
Nobby
Postby LateAgain » Mon Dec 07, 2015 10:04 am
Make two sets please Nobster... one for me, one for thee, call it payment for the Kwakers.
LateAgain
Users browsing this forum: No registered users and 60 guests
