What are the differences between the AF Clubmans?
Re: What are the differences between the AF Clubmans?
Postby Captain Pugwash » Wed Dec 02, 2015 10:32 pm
Dimitrios, I'm looking forward to the finished build 8-)
Captain Pugwash
Postby Dimitrios_231 » Wed Dec 02, 2015 10:44 pm
I hope it won't go bang at the first ride,a 252.25cc Rapido can never be famous for reliability :lol:
I forgot to say that I'll run it with a single piston ring :shock:
Excuse me,the conrod is 110mm not 100mm :)
Dimitrios_231
Postby Warkton Tornado No.1 » Thu Dec 03, 2015 3:00 am
It would be good if you could let us see a video of the first start up.
I can't help wonder if you are likely to encounter heat issues with the tailpipe size. Perhaps I've misunderstood, but if it is only Ø20 mm bore, I doubt that's adequate for the rest of your set-up.
God Luck with it though!
Postby Dimitrios_231 » Thu Dec 03, 2015 2:45 pm
I trust Mr.Gori for his tailpipe diameter decisions :o :)
Earlier I matched the u-bend to the cylinder.
I took again measurements from this u-bend.
U-bend max diameter : O/D 55.20mm I/D 52.50mm
Tailpipe diameter : O/D 22.20mm I/D 19.85mm
Main Box entry diameter : O/D 58.50mm I/D 55.60mm
Dimitrios_231
Postby Warkton Tornado No.1 » Thu Dec 03, 2015 9:51 pm
Everything depends upon the state of tune & your riding style. My conscience is relieved that I've made you aware.
I'm fairly certain that sustained flat out riding with something that should deliver 25 plus bhp @ the back wheel would result in a build up of heat on a bleed anything less than Ø 25 mm (especially using pump fuel rather than Avgas) if I were to ride it as precisely that occured before I learnt my lesson. It was Ø 22 mm to be precise, based upon calculations, of course!
Postby Dimitrios_231 » Thu Dec 03, 2015 10:18 pm
Thank you for the valuable input ;)
If something goes wrong,I have a spare 72.5mm piston,I'll cut the exhaust, open it and fabricate a larger diameter tailpipe.
Engine is on the frame now.
Dimitrios_231
Postby Dimitrios_231 » Sun Dec 06, 2015 1:05 pm
Still waiting for Tino's special part.
I couldn't wait,checked spark.
OK :D
Dimitrios_231
Postby Dimitrios_231 » Sun Dec 06, 2015 8:05 pm
Few gentle first run revs,
I run it without the tailpipe endcan,I don't like the look of it,I'll keep it only for the MOT.
Dimitrios_231
Postby Dimitrios_231 » Sat Dec 12, 2015 3:05 pm
Testing week,
love the noise,I mean the sound :)
need to fine adjust carb jetting.
Dimitrios_231
Postby dickie » Fri Feb 19, 2016 8:10 am
So what's it like on the road dimitrios?
I'm really interested in the gp50 for my ts1.
Postby Dimitrios_231 » Fri Feb 19, 2016 10:47 am
I'm happy with it,
can't compare it with another exhaust as I had done extra work on the cylinder plus I changed the gearing (to shorter) before I use the GP50.
Dimitrios_231
Users browsing this forum: No registered users and 39 guests
