Adam_Winstone wrote:I need to do similar some time too. However, looking at that makes me wonder if you could not fit an extended nut to what's left and then fit another short length of studding to that. This wouldn't be a great repair but might be a very functional fix.
rossclark wrote:As its behind the badge couldn't you just drill it out and tap put a countersunk screw through?
MickYork wrote:I'd cut off flush, drill and tap the hole, then fit a new stud.
gaz_powell wrote:I think Adam was refereeing to these - it will give more thread to bike - cheap and easy fix
http://www.ebay.co.uk/itm/ALLTHREAD-ROD ... NcMMbxvG_w
or
http://www.ebay.co.uk/itm/THREADED-ROD- ... 1765850513
Gaz
Warkton Tornado No.1 wrote:I'm fairly certain that they are M6 (x 1.0 pitch). It's too late to check in my garage!
The suggestion (Adam's) of a long nut would work as the studs fit through massive holes in the frame. If the fasteners are M6, Toolstation sell ten for less than a quid. You might have to shorten them a bit though.
Let us know how you get on, please.
