tight manifold
tight manifold
Postby Scooterslag » Mon Nov 30, 2015 6:27 pm
just putting together a engine and using a stock 20mm delly and manifold which I bought from separate sources, problem being is the manifold is way too large to insert (oh er... :D ) into the carb body, any decent tricks or tips to get the buggers to fit without knackering anything? cheers Paul
Re: tight manifold
Postby Adam_Winstone » Mon Nov 30, 2015 6:33 pm
Sure the manifold isn't intended for a 22mm carb?
Re: tight manifold
Postby drivera » Mon Nov 30, 2015 6:52 pm
Either find someone with a lathe who could turn down the spigot to the correct size or set too with a file ( might take a while though ) :)
drivera
Re: tight manifold
Postby Scooterslag » Mon Nov 30, 2015 7:14 pm
Adam_Winstone wrote:Sure the manifold isn't intended for a 22mm carb?
Nope it the right type Adam 19.41.1004, the 20mm is off a serveta while the manifold is italian, don't know if this makes any difference, its just bloody tight :) Paul
Re: tight manifold
Postby Scooterslag » Mon Nov 30, 2015 7:16 pm
drivera wrote:Either find someone with a lathe who could turn down the spigot to the correct size or set too with a file ( might take a while though ) :)
yeah I was going to set to it with a file and emery cloth, I just wanted to see if there was a easier way. Paul
Re: tight manifold
Postby Covboy » Mon Nov 30, 2015 11:00 pm
Hi
The nylon insert reduction sleeve that goes into the carb body - I think that there are different sizes ( ie different inside diameters ) for different manifolds .
http://www.scooterrestorations.com/lamb ... on-sleeve/
Users browsing this forum: Baidu [Spider] and 172 guests
