Knowledge wrote:Getting this scooter running would be the best Christmas present you could give yourself.
Adam_Winstone wrote:Soz if this has been covered already but you've not swapped out stators for one that has the Indian market colours have you, which a pal of mine did recently? Once he had twigged to the colour differences his motor barked up immediately... but spent ages trying to find other causes before seeing the issue. In this case my pal was swapping a failed Italian one for a known working Indian one but then got the colours wrong.
LateAgain wrote:... another way.
Put a known running motor into your frame. If it barks up you can discount frame, loom, CDI, ignition switch etc etc. then you can discount all of your 'static' components. Then 'simply' replace components from your duff motor onto the runner one component at a time until it fails. Hey presto, fault found. If it doesn't bark up, your frame components are at fault, not the motor. Worth a shot?
dickie wrote:did this ever get resolved?
Users browsing this forum: Baidu [Spider], Google [Bot] and 64 guests
