who asked if I could do this; so before I start drilling... did you measure these across the metal of the legshields, or are are they straight lines using a caliper ?byron wrote:...will pass that on to the painter
yep, worthwhile point, but it's all good, the new badges to fit are with the painter, so will be using them to check hole positioning.foremanbob wrote:... mark for drilling using the real badges....
thanks, good tip, and lovely scooterWack wrote:...Don't forget the Lambretta script doesn't sit horizontal but slopes down to the beading.
byron wrote:who asked if I could do this; so before I start drilling... did you measure these across the metal of the legshields, or are are they straight lines using a caliper ?byron wrote:...will pass that on to the painter
brilliant, I was expecting and hoping you'd done that, should be loads easier to replicate. thanks again Russcarlos fandango wrote:Straight line with a caliper .
CHRIS in MARGATE wrote:Just saved those images myself.
carlos fandango wrote:CHRIS in MARGATE wrote:Just saved those images myself.
FFS I should of copyrighted them ! Lol
TBH
It would be good if we had a library of things like this on the forum , maybe in the members area ?
Im thinking of badge hole positions for all models, ink splat position etc. Frame dimensions and lots of other std stuff
carlos fandango wrote:But yeah , I suppose the relevant model section would make sense
Users browsing this forum: Google [Bot] and 174 guests
