Compression test
Compression test
Postby kennystag » Sat Nov 07, 2015 5:10 pm
Hi All,
I put a Compression tester on my GP150 and it reads 90 PSI which I think is very good, anybody know what the PSI should be on a standard engine with about 6,000 km.
Stag
:D
kennystag
Re: Compression test
Postby Captain Pugwash » Sat Nov 07, 2015 9:53 pm
It depends a little on how fast you can kick over the engine But I would expect 90psi to be ok. I've had higher readings.
Captain Pugwash
Postby Raveydavey » Sat Nov 07, 2015 11:16 pm
Stick it in 2nd and push it to turn the engine over rather than kicking it. 120 psi is a healthy compression
Raveydavey
