Carello rear light lamp holder? slightly geeky...
Postby Andie » Sat Nov 07, 2015 2:45 pm
hello - my rear light unit - carrello 6.135.580 has previously been soldered into the loom. Which is fine, nice and secure, but a bit scruffy...
The bulb holder is now filled with solder.
I've searched for bulb/lamp holder but can't find one - I wondered if anyone could point me in the direction of a suitable replacement holder?
It appears to be just crimped over on the lens side of the unit.
Andie
Re: Carello rear light lamp holder? slightly geeky...
Postby Rich Oswald » Sat Nov 07, 2015 4:05 pm
I have an original bulb holder from my SX, don't know the part number but it's yours if you want it Andie,
Postby Andie » Sat Nov 07, 2015 4:17 pm
Thanks Rich' - PM on its way :)
Andie
Postby Andie » Sun Nov 29, 2015 10:58 pm
hello
I am still working on this. Rich' kindly had a look but the SX part he had spare wasn't an option.
I need to remove the bulb holder, which is crimped in, and 52 years old so I have little confidence in it coming out and going back safely - the unit will then be blasted and powder-coated.
If anyone has experience of replacing this part I'd be grateful, many google searches (including Carello sites) haven't gleaned anything useful.
Thanks - Andrew
Andie
Postby duncan1958 » Mon Nov 30, 2015 9:28 pm
I gently bent the ears back on mine ,lost a few in the process.
Once back together after painting I used some metal glue to hold it more securely in place,as in stop it turning when installing the bulb.
duncan1958
