Fork
Fork
Postby eyeguy » Mon Nov 02, 2015 8:10 pm
Hi all , would the fork from a LI fit a TV 175?
Eyeguy
eyeguy
Re: Fork
Postby Dimitrios_231 » Mon Nov 02, 2015 9:02 pm
99% Yes :)
The only difference will be the welded bracket for the dampers,
assuming you won't mix S1/2 with S3.
Dimitrios_231
Re: Fork
Postby eyeguy » Mon Nov 02, 2015 9:24 pm
Could brackets be welded on?
eyeguy
Re: Fork
Postby Dimitrios_231 » Mon Nov 02, 2015 9:28 pm
Sure,it is not difficult especially if the fork is out and stripped,
take care not to weld the brackets while the plastic spring stops are inside,they will melt.
Dimitrios_231
Re: Fork
Postby eyeguy » Tue Nov 03, 2015 2:14 pm
Thanks guy's
eyeguy
Re: Fork
Postby eyeguy » Wed Nov 04, 2015 2:02 pm
Sorry to second guess the fork issue but, the guy doing work on my TV stated the fork from an LI must have the chrome ring as mine does or it won't fit. Help again
Eyeguy
eyeguy
Re: Fork
Postby Andyf » Sun Nov 08, 2015 11:12 pm
the headset is matched to the forks/chrome ring.
Andyf
Users browsing this forum: No registered users and 56 guests
