by paulack » Mon Oct 26, 2015 9:48 pm
Hi
l am a new member and need some advice I have a s3 and would like to fit front dampers I am considering using fork links with damper connection are these difficult to fit.
paulack
by HxPaul » Mon Oct 26, 2015 9:54 pm
If its a series 3 Li,TV,SX,you will need a fork spring compressor,if its a GP or later SX with damper rods and ball bearings its possible to remove without a fork spring compressor.
by Digger » Tue Oct 27, 2015 10:28 am
The first one you do may take you up to two hours, much cursing and bruised fingers.
The second one about 10 minutes.
Make sure you use a decent compressor tool as there are some crap ones on the market.
Digger
by paul213 » Wed Oct 28, 2015 10:55 am
be careful which links you use there were some nasty sand cast ones about . tried fitting a set for someone and one snapped where the spindle goes during fitting .
paul213
Users browsing this forum: No registered users and 94 guests
