ScootRs front disc brake binding
Postby Revvers » Tue Oct 13, 2015 11:47 am
Hello all. I've been having some issues with my front (cable) disc brake from ScootRs, in that, it seems to bind on as I'm riding. I've been told that there's an inherent manufacturing problem with the remade actuator arm(??) Has anyone else had this issue, and if so, any solutions? I imagine nos must be rare as hens teeth and rediculously expensive!
Revvers
Re: ScootRs front disc brake binding
Postby dickie » Tue Oct 13, 2015 12:29 pm
Scootopia did an arm that (apparently) cured this, but they're out of stock.
They are about £40 and I've asked them if they're getting any more but have had no response.
Give them a shout; maybe they'll respond to market demand!
Postby Revvers » Tue Oct 13, 2015 12:56 pm
Cheers Dickie
Revvers
Postby drivera » Tue Oct 13, 2015 1:18 pm
A few original ones turn up on flea bay for around £20 - £30 , and apparently ScootRS now make a stronger version of the arm but not sure how much stronger the spring is !!
drivera
Postby Covboy » Tue Oct 13, 2015 2:54 pm
I experience the same problem on two units -its infuriating - the brake stays on when the spring doesn't return. My scootsrs discs are fairly new (<9 months) so I suspect that the "stronger" spring is fitted. :(
Postby Revvers » Wed Oct 14, 2015 2:12 pm
Think I'll contact ScootRs and see if they acknowledge the issue. I notice their new op arm was added in Jan 15, so maybe, Covboy, you haven't got it(???) anyhoo, I think they should do a discount on the newer version. I'll let you know how I get on
Revvers
Postby HxPaul » Wed Oct 14, 2015 5:04 pm
I've got a scootRS front disc brake,my brake arm didn't return so I fitted a compression spring on the cable between the actuator and the brake stop on the backing plate,this did the job and it returns ok now.
Postby Revvers » Thu Oct 15, 2015 8:45 am
No reply from ScootRs as yet. Paul, how did you fix that spring? Is it an easy (ish) job?
Revvers
Postby HxPaul » Thu Oct 15, 2015 10:16 am
Revvers wrote:No reply from ScootRs as yet. Paul, how did you fix that spring? Is it an easy (ish) job?
I've set my brake cable up as a reverse pull and the compression spring fits on the cable between the brake actuator and the adjuster that fits through the brake stop hole on the back plate.It's a two minute job. www.ilambretta.com/reverse.html
Postby Revvers » Thu Oct 15, 2015 10:49 am
Thank you
Revvers
Postby Revvers » Wed Oct 21, 2015 9:32 am
Just an update. Sent an email to the lads at ScootRs, quick response and very satisfactory conclusion. Great customer service. Uprated spring required
Revvers
Postby Covboy » Wed Oct 21, 2015 9:31 pm
Hi Revvers - are they supplying FOC ?
Postby Revvers » Mon Oct 26, 2015 3:34 pm
Sorry for the delay! Yes mate, that's what they said
Revvers
Users browsing this forum: Baidu [Spider] and 90 guests
