Dellorto overflowing
Postby Wack » Sun Jun 29, 2014 6:38 pm
I'm running a VHSB 39 with all new internals but on the overrun fuel is poring out of the overflows. I've stripped it and everything seems fine running a 3.5 fuel valve. The scoot doesn't leak when stood or riding under power just floods on the overrun after a blast. Any ideas?
Re: Dellorto overflowing
Postby Fat Trucker » Tue Jul 01, 2014 12:45 pm
Sounds like the float is sticking open at some point, but somebody else may have a better idea.
Fat Trucker
Postby St George » Tue Jul 08, 2014 5:46 pm
Sounds like it is stuck open. Can you adjust the float on that model ? You will find that a 350 will let gallons into the carb, will need a fine balance.
St George
Return to Carburettors
Users browsing this forum: Bing [Bot] and 35 guests
