Meds wrote:I have had similar problems in the past and worked round it using Coasters method.
The underlying fault in my case was timing. It was only found when a mate strobed the engine and found the static timing marks and firing point were 3 degrees different.
Andie wrote:Hello. i recently posted about potential spit back problem with sealed 22mm bellows.
I would ideally like to enable a 22mm bellows to have a S3 18 or 20mm one way valve present (so as not to muck about with air intake source).
Possibly one for after-marketers to look at as I think there is a demand.
However - A few people suggested ways of making a drain in the sealed hose. I'm told it seems to work.
All the best, hope you sort it.
pip wrote:Had plenty of trouble with hot starting with jetex carbs and found winding throttle open with petrol off before starting usually worked.
bigbthesoulman wrote:Had problem for years,tried everything ,even enginer rebuild,New carb the lot,took to old boy I know workedw ith Lambretta s years ago,phoned me up wrong choke cable,was to short,when Sat on bike put it on,no free play,and bigger pilot jet he said,I have never looked back,standard 150 set up with 20 mm Dell mind you
Users browsing this forum: No registered users and 84 guests
