by kennystag » Thu Oct 22, 2015 6:20 pm
When referring to a electronic ignition with a large cone, are they meaning the centre of the flywheel, i.e. a GP has a large cone.
Stag.
kennystag
by Wack » Thu Oct 22, 2015 6:43 pm
That's how the Germans describe cranks so I would say yes.
by kennystag » Fri Oct 23, 2015 3:55 pm
Hi all,
Looking for information. Am I correct in saying that the Indian GP150 flywheel has a large cone and small fins. Your help will be appreciated, as I want to get it right if I buy an electronic ignition kit for my GP.
Stag
kennystag
by HxPaul » Fri Oct 23, 2015 5:29 pm
The only time I've seen electronic ignition systems to fit "large cone or small cone"is when there advertised by Indian companies on ebay.They are normaly described by reputable dealers as being to fit a"large taper or small taper"crankshaft.Buying something from India on ebay is very dodgy,you might get a bargain,then again you might get stung.If it were me I'd spend a bit extra and buy from a reputable dealer.
HxPaul on Sun Oct 25, 2015 5:25 pm, edited 1 time in total.
by nickw » Sun Oct 25, 2015 12:21 pm
^ What he says. Also the flywheel fins can be short or long. Depends on the flywheel cover you have. Personally buy from Scooter Restorations. His prices ain't bad and they check all their flywheels and wiring. You're also dealing with someone who is based in England and will respond to any problems. There are other dealers out there
nickw
Users browsing this forum: No registered users and 55 guests
