200gp
200gp
Postby Bugracer69 » Thu Oct 22, 2015 9:18 pm
Hi all
Can any bode help
I have a lndian gp200 ang would like to put a tar evo exhaust on, any idea of jetting please
Scooter is all standard accept air filter
Any help would be great
Bugracer69
Re: 200gp
Postby rossclark » Thu Oct 22, 2015 11:07 pm
What carb is fitted?
Re: 200gp
Postby Bugracer69 » Fri Oct 23, 2015 7:02 am
Hi there, it's a standard carb - I think it's a PH22 - cheers
Bugracer69
Re: 200gp
Postby MickYork » Fri Oct 23, 2015 7:30 am
maybe give TSR a call and see what their recommendations are........they'll probably be able to supply the jets required as well (the air filter may require modification/change as well).
Re: 200gp
Postby hullygully » Fri Oct 23, 2015 10:13 am
apart from looks 8-) , the EVO might be a bit of over kill for a std engine / carb etc.... :(
if you want a better performance but retain its std looks then why not go for an AF big bore / Ancillotti / MB Clubman? ;)
Re: 200gp
Postby pip » Fri Oct 23, 2015 2:09 pm
TSR Evo has poor ground clearance and won't run well with a standard carb as it won't feed enough fuel, I know from experience. Go for a clubman type exhaust.
pip
Return to Carburettors
Users browsing this forum: No registered users and 35 guests
