TDC TOOL
TDC TOOL
Postby kennystag » Thu Oct 15, 2015 7:24 pm
Hi all,
Anybody used TDC tool, are the any good for checking the timing.
Stag
http://www.ebay.co.uk/itm/TDC-FINDER-TO ... 2ee6f384b8
kennystag
Re: TDC TOOL
Postby dickie » Thu Oct 15, 2015 7:33 pm
I use one. It's ok, but use it as a stop rather than to find tdc itself, if you know what I mean.
The piston barely moves for a few degrees either side of tdc, so you need an accurate dial gauge to find tdc.
Re: TDC TOOL
Postby gaz_powell » Thu Oct 15, 2015 7:50 pm
I bought one but to be honest the calibration/measurement part is useless as already stated. Just make a stop from a spark plug (see stickys book) cost you 15 minutes and does the same job for the positive stop method (which I use all the time)
Re: TDC TOOL
Postby Tractorman » Thu Oct 15, 2015 9:42 pm
You could make one with an old spark plug and an m8 nut and bolt.
Re: TDC TOOL
Postby Storkfoot » Thu Oct 15, 2015 11:53 pm
I have always used one of those. But, you do have to rock the flywheel back and forth and have a keen eye.
The reason being that when you get near TDC the flywheel will keep turning but the "stop" stops moving. I gauge the midpoint between the "stop" stopping moving and then starting again. But, I check this point several times before I am sure I have TDC.
Many people favour measuring the midpoint between TDC and BDC. Personally, I think that is more liable to be wrong but it's all personal choice.
Re: TDC TOOL
Postby Tractorman » Fri Oct 16, 2015 8:42 am
Storkfoot wrote:I have always used one of those. But, you do have to rock the flywheel back and forth and have a keen eye.
That's right the dwell point can be several degrees on the flywheel that is why IMO a fixed one set a few degrees before TDC is more accurate.
Re: TDC TOOL
Postby Dimitrios_231 » Sat Oct 17, 2015 3:18 pm
Not always possible,
but...
...if the engine is out,I prefer this method.
Dimitrios_231
Re: TDC TOOL
Postby kennystag » Sat Oct 17, 2015 4:22 pm
Excellent you can’t go wrong with a dial gauge. If I fit electronic ignition I will use my dial gauge. I like the gauge stand, did you made it up yourself.
Stag
kennystag
Re: TDC TOOL
Postby Dimitrios_231 » Sat Oct 17, 2015 4:57 pm
Cheers,it is an original workshop tool for 125/150 and 175 cylinder studs spacing.
I also have a vintage TDC tool like the one that you described, next to a modern piston stop,
it is not as accurate as the dial gauge but it works.
This one is a remade for 200cc blocks.
Dimitrios_231
Re: TDC TOOL
Postby kennystag » Sat Oct 17, 2015 5:13 pm
Cracking tools mate,
I think I will have a go at making a dial gauge stand. I made a TDC tool with an old spark plug, same spec as in stickys book, but the dial gauge is the way to go for getting the timing set properly.
Stag
kennystag
Users browsing this forum: Google [Bot] and 34 guests
