by xenia1 » Fri Jul 04, 2014 12:07 pm
S1/2 stand sleeves, possibly thin tubular plastic? Anyone make/use them during a rebuild? Its just to save metal to metal contact..
xenia1
by foremanbob » Fri Jul 04, 2014 11:27 pm
Not quite the same thing... but I use motorcycle dry chain lube for exactly the same task... It lubricates, but does not attract grit in the same way that grease does.
foremanbob
by xenia1 » Sun Jul 06, 2014 7:25 pm
Thanks for the reply foremanbob, ive used similar grease on my previous S1 and ptfe tape on my Tv1 but was asked by a guy building his frame up for suggestions. and came up with plastic tubing but whether this would clamp up preventing the movement of the stand i dont know...trial and error i suppose..
Andy.
xenia1
by Jazzy b » Sun Jul 06, 2014 7:39 pm
Hi Andy what about heat shrink ?
Jazzy b
by roli150lam » Sun Jul 06, 2014 9:10 pm
Why not line the j bracket with plastic tube(cut in half lengthways).Maybe less hassle.
roli150lam
by xenia1 » Mon Jul 07, 2014 8:59 pm
Two more ideas, thanks guys..
xenia1
by Wack » Mon Jul 07, 2014 10:03 pm
Plastic pop bottle?
by xenia1 » Wed Jul 09, 2014 9:04 pm
Wack wrote:Plastic pop bottle?
Thats the sort of thickness i reckon...
xenia1
