kit for a j50
Technical help for Lui, Vega, Cometa, J50, Cento, J125, Starstream.
kit for a j50
Postby terryj » Tue Oct 06, 2015 8:47 pm
asking for my postman
he has brought a j50 and wants to up the performance a bit
is there anything available and where from
thanks
terryj
Re: kit for a j50
Postby Wack » Wed Oct 07, 2015 6:27 pm
Re: kit for a j50
Postby terryj » Thu Oct 08, 2015 9:26 pm
thanks been looking at that
can you do anything on the gearing on the j50
also is the j125 and j50 the same engine with different top ends so he could just fit a j125 top end
terryj
Re: kit for a j50
Postby Wack » Fri Oct 09, 2015 5:59 pm
There's sprockets available for the kit but although the 50 and 125 are both 3 speed I'm not sure if the top ends are interchangeable, the crank would need changing at a guess. Try the Luna forum as someone's bound to have done one. Or consider a new motor. http://www.scooterrestorations.com/lamb ... -assembly/
Return to Luna & J Range
