12v electronic flywheel
Postby HxPaul » Mon Oct 05, 2015 5:24 pm
Does anyone know where the trigger point is on this flywheel.I know its in between the 2 magnets with the fingers on,but where I havn't a clue.I have three 12v flywheels and each one has different timing marks.Each time I rebuild an engine I use a strobe on the flywheel and each time I have to remove the flywheel to adjust the stator plate,this is a pain and I'd just like to strobe it and find that its in the right place.
Re: 12v electronic flywheel
Postby rossclark » Mon Oct 05, 2015 6:42 pm
The timing marks are arbitrary. I wouldn't trust the two lines scribed in the windows on anything other than an original or an original Ducati AF flywheel.
The arrow can be stamped anywhere or make your own mark on the flywheel and line that up at TDC then mark the mag flange with your TDC and your timing mark.
Postby HxPaul » Mon Oct 05, 2015 8:16 pm
There must be a trigger point on all 12v flywheels,its just that I have 3 flywheels and everyone has the timing marks(the 2 lines)in a different place.I just thought that finding this trigger point would make timing a lot easier.
Postby rossclark » Mon Oct 05, 2015 9:48 pm
The two lines are almost invariably untrustworthy except as above.
Best to use the arrow and make some marks round the rim of the mag flange for your TDC and firing point
Postby HxPaul » Mon Oct 05, 2015 9:54 pm
I know there untrustworthy,thats why I'm asking if anyone knows the exact trigger point.
Postby rossclark » Mon Oct 05, 2015 9:57 pm
If the people who make them can't get it right, what chance do we have?
Users browsing this forum: No registered users and 155 guests
