top end
top end
Postby 59 lammy boy » Sun Jul 06, 2014 11:47 pm
What 185 top end would you recommend for a small block?
I don't want to buy the £70 kits off eBay and I haven't got the money for the gt kits
What I'm looking to buy is something in between that is a good reliable head and barrel kit with good clean transfere posts etc
59 lammy boy
Re: top end
Postby Toddy » Mon Jul 07, 2014 6:25 am
Most of the decent 185-200 small block kits are between £400-£550 plus the extras you may need to fit , you may be better looking for a second hand one or try
getting your esxisting set up ie 150 tuned and ported by a reputable dealer .
Re: top end
Postby Donnie » Mon Jul 07, 2014 9:46 am
Agree there, you're looking at decent money for most upgrades from a 150, unless you go for a half decent 175 thats been sorted properly, or the other alternatives a suzuki conversion second hand, you should pick one up for less than £100 if you can find one.
Donnie
Re: top end
Postby corrado » Mon Jul 07, 2014 1:40 pm
Harry Barlow usually has some sorted sub 200 kits at Wicksteed for decent money, Suzuki etc. He's worth having a chat with.
info@pro-porting.com
0116 2871285
corrado
Re: top end
Postby Rich Oswald » Mon Jul 07, 2014 4:31 pm
There are some 185 Alloy kits that some dealers are re working to make them usable. I think Buzz Solomoto does this. A few people have had good results from them.
Re: top end
Postby Steve J » Tue Jul 08, 2014 7:28 pm
Isn't one of the problems with the cheap 175/185 alloy barrels with iron liner that the liner itself is soft, and wears fairly quickly?
Steve J
Re: top end
Postby Storkfoot » Tue Jul 08, 2014 8:20 pm
Steve J wrote:Isn't one of the problems with the cheap 175/185 alloy barrels with iron liner that the liner itself is soft, and wears fairly quickly?
Yes, but in my experience it also depends on the rings. I had one set of rings which were totally destructive to an SR barrel whereas a Racetour piston and rings were relatively OK :|
Re: top end
Postby lofty » Fri Jul 11, 2014 3:57 pm
there was a massive thread on the old forum about the 'SR' kits and how they can be made to work..
however you will need to be handy with the dremel or pay someone who is handy, I run one on my TV175 and it works very well (touch wood!!)..
alternatively just get an iron barrel bored, ports opened and use a clubman and 22+mm carb, it will give a reasonable boost to performance at a moderate cost..
lofty
Re: top end
Postby Scooter Paul » Fri Jul 11, 2014 5:35 pm
On a tight budget I'd agree with Lofty. Get the original barrel bored to 175 with ports matched to manifolds and use a quality clubman and a sorted 22mm Jetex.
Paul
Scooter Paul
Re: top end
Postby MickYork » Fri Jul 11, 2014 5:49 pm
Get your casings sorted to take the 200 stud configuration (costs £150 ?) then use a stage four 200 barrel and piston (£100 ?).
Re: top end
Postby 59 lammy boy » Sun Jul 13, 2014 2:58 am
Thanks for all your help and advise.
I have now bought a very good second hand imola 186 kit
59 lammy boy
Re: top end
Postby bluebob » Mon Jul 14, 2014 7:37 pm
just following mickyork,s comment about casings,the old forums had some good threads on this,recall there was a good video clip aswell.anyone got any recommendations for the work.
cheers
bluebob
Re: top end
Postby MickYork » Mon Jul 14, 2014 7:52 pm
There you go. Oiltek, based in South Yorkshire
https://www.youtube.com/watch?v=E3EmdUUFpzc
Re: top end
Postby bluebob » Mon Jul 14, 2014 7:59 pm
nice one mick
bluebob
Users browsing this forum: No registered users and 47 guests
