Clutch drag
Clutch drag
Postby stonerosesmod » Sun Sep 27, 2015 5:10 pm
Anyone had issues with MBD clutch springs? Been having issues with clutch drag for a while since I fitted them,and just replaced the chain as old one was slack on the adjusters limit and noticed the springs were all slightly bent at one end as if they have been kinked over? May be contributing towards the drag as everything else,plates etc looked fine.Even with clutch over adjusted it tries to creep in 1st now.Might have to get some standard GP springs as it had before.Its on my Li150 with a 198 mugello.
stonerosesmod
Re: Clutch drag
Postby Storkfoot » Sun Sep 27, 2015 8:34 pm
I have used MB springs for several years now. I have found them to be very good and often just fitting them has resolved any clutch slipping I may have had. You do have to replace them every year or so though as they do compress.
I am struggling to see how they could have all bent over though if the clutch was operating well. Did you buy these from MB?
Re: Clutch drag
Postby Wack » Sun Sep 27, 2015 8:53 pm
Presumably they were centered when first fitted so check the pressure plate as some don't have a deep enough rebate for the springs to fit in correctly.
Re: Clutch drag
Postby stonerosesmod » Mon Sep 28, 2015 6:06 am
Yes, propper MB ones and i made sure they were seated properly. They were only just offset at the ends which i though was strange.May order a new set and try again.
stonerosesmod
Re: Clutch drag
Postby Raveydavey » Mon Sep 28, 2015 9:45 pm
Might be there's not enough clearance between the actual plates rather than the springs
Raveydavey
Re: Clutch drag
Postby Captain Pugwash » Mon Sep 28, 2015 9:58 pm
Maybe try a complete clutch build without the springs and see how much free play you've actually got , could be any of a few of things causing the clutch to drag.
Captain Pugwash
Re: Clutch drag
Postby stonerosesmod » Tue Sep 29, 2015 6:02 am
Ok thanks,will try that :)
stonerosesmod
Users browsing this forum: No registered users and 49 guests
