Direct cooling v cowlings
Re: Direct cooling v cowlings
Postby Scooterlam » Sun Sep 20, 2015 6:57 pm
does the temp rise when you stop moving.
if not it might be worth checking the sensor with a hot air gun.
my sky drive sensor read lower and lower as it failed,
Better safe than sorry.
Scooterlam
Postby lozmondo » Mon Sep 21, 2015 2:32 pm
yes temp does move up when stationary then drops back once moving
lozmondo
Postby dickie » Fri Sep 25, 2015 7:44 pm
I have just bought an avanti head for my ts1 build which I'll be running with cowling and full bodywork on a series 2.
I don't want to fit a sip speedo or any other type of temperature gauge, simply because I want everything external to look original.
This isn't going to be a superpowerful motor. Probably in the region of 20bhp or a bit less.
Am i being foolish?
Postby Warkton Tornado No.1 » Sat Sep 26, 2015 3:00 pm
You are replacing a cylinder head with one that has been designed to shed more heat than the standard Lambretta product. That could only be a problem if it compromised other factors such as the cooling available to the cylinder, changed your squish, your compression ratio etc.
So, it's doubtful that you are being foolish.
The foolish one's are those that fit a big head 'to be safe' then limit it's function by not optimising other areas. Optimising the squish means the head draws heat from the piston. Having a squish of, say, 2.5 mm 'just to be safe' completely wrecks that concept in it's purest form.
Only my opinion, mind you.
Postby dickie » Sat Sep 26, 2015 4:44 pm
Thanks warkton but I was wondering if not fitting a temperature gauge was foolish. I have no doubt that the avanti head is a good move, but I'm hoping to rely on it to keep everything so cool that I can forget about fitting a temp gauge.
See what I mean?
Postby Warkton Tornado No.1 » Mon Sep 28, 2015 11:08 am
It all depends upon how much of a risk taker you are.
EGT's are arguably of the most benefit, their positioning & reaction just has got to be superior to components placed on the outside, rather than inside the combustion process.
But for what you are doing, sensibly, I guess, it's not essential.
With respect, those that are striving to optimise their engines, which is fantastic & god reading, will be the people where monitoring the engine more is essential.
Does that make sense?
Postby dickie » Mon Sep 28, 2015 9:51 pm
Complete sense. Thanks
Users browsing this forum: Google [Bot] and 45 guests
