TV200 gearbox
TV200 gearbox
Postby onekick66 » Sun Jul 06, 2014 9:28 am
muggy 200, 42 clubman, 25m delly,,
any ideas on what front /rear sprockets to use,,
using original gearbox setup at moment, and 4th gear is shite more like a overdrive,
have to change down in head wind,,
onekick66
Re: TV200 gearbox
Postby petemaisey » Sun Jul 06, 2014 10:14 am
A 14/47 sprocket set up would improve the top gear (if you can get the sprocket and chain). However it will give you a lousy lower set of gears and you will still have a big gap 3rd to 4th.
A top gear ratio of around 4.8/4.9 or even 5 to ensure good pulling two up on hills, would suit you. Use an Li150 or Li125 gearbox, nice close ratios and most easily obtained.
Pete
petemaisey
Re: TV200 gearbox
Postby onekick66 » Sun Jul 06, 2014 12:58 pm
hi pete been told the 14/47 setup burnt out clutches, with the front sprocket being so small ???
onekick66
Re: TV200 gearbox
Postby petemaisey » Sun Jul 06, 2014 1:05 pm
Thats right, the larger the front sprocket the better Get an Li gearbox.
Pete
petemaisey
Re: TV200 gearbox
Postby onekick66 » Sun Jul 06, 2014 1:25 pm
thanks pete,, ;)
onekick66
Re: TV200 gearbox
Postby badal1965 » Wed Jul 09, 2014 3:29 am
And ebay the TV200 box to all the mugs.Sorry "collectors" :roll:
badal1965
Re: TV200 gearbox
Postby Digger » Wed Jul 09, 2014 5:28 am
badal1965 wrote:And ebay the TV200 box to all the mugs.Sorry "collectors" :roll:
A chap in our group runs a TV200 box on a Indian 200 top end end.
He's just over 5 feet tall and weighs next to nothing - the combo works very well - very well indeed.
So not everyone buying on Ebay is a 'mug' or 'collector'. ;)
Digger
Re: TV200 gearbox
Postby wibblethorpe » Wed Jul 09, 2014 5:56 am
I am not a mug or a collector but the TV 200 gearbox I've just bought off E bay goes well with the TV 200 barrel.
Impressed with a standard cast 200 pulling the 4.4 final drive.
wibblethorpe
Users browsing this forum: Google [Bot] and 85 guests
