by Lambo » Fri Sep 11, 2015 2:07 pm
I'm currently on the look out for some original LI special side panels. I've found some Spanish panels but before I spend the money can anyone tell me if they are the same as the Italian ones and will fit? Don't want to waste my money if they are different, cheers.
Lambo
by pacemaker » Fri Sep 11, 2015 4:25 pm
Spanish are wider than Italian
pacemaker
by Lambo » Fri Sep 11, 2015 6:01 pm
Thanks, maybe I'll holed out for Italian panels then.
Lambo
by ToBoldlyGo » Fri Sep 11, 2015 6:31 pm
It depends how pernickety you want to be. The Spanish ones would fit and it would take an expert to tell the difference.
ToBoldlyGo
by Lambo » Fri Sep 11, 2015 6:36 pm
ToBoldlyGo wrote:It depends how pernickety you want to be. The Spanish ones would fit and it would take an expert to tell the difference.
Fair enough, would you expect to pay more for Italian panels? I know panels aren't cheap anyway
Lambo
by Nobby » Fri Sep 11, 2015 7:10 pm
Lambo wrote:ToBoldlyGo wrote:It depends how pernickety you want to be. The Spanish ones would fit and it would take an expert to tell the difference.
Huuum not sure about 'it would take an expert', it's quite a big square edge to to the Spanish ones ! (About an inch flat lip compared to a 10mm rounded edge on Italian) , personally I'd wait for some good Italian ones- is spot Spanish on an Italian scooter straight away? ...
Nobby
by Lambo » Fri Sep 11, 2015 11:02 pm
Nobby wrote:Lambo wrote:ToBoldlyGo wrote:It depends how pernickety you want to be. The Spanish ones would fit and it would take an expert to tell the difference.
I think that's what I'm going to do to be honest, I'm sure a pair will come along. Thanks for the advice
Lambo
