How to calculate port timings?
Postby Donnie » Fri Sep 11, 2015 11:47 am
From my thread about how to get a proper squish and Im wondering overnight now if I should go through the port timings etc and find out what they are as I still don't know what exhaust im going to end up with can anyone recommend an idiots guide on how to do this?
Ive googled and there seems to be an array of information but think im confusing myself more and more.
Is there any website / you tube clips that anyone on here would recommend?
Donnie.
Donnie
Re: How to calculate port timings?
Postby dickie » Fri Sep 11, 2015 6:14 pm
Put a degree disc on your crank.
Mark tdc
Make sure barrel is fully seated but with head off
Use a very thin feeler gauge, say 0.1mm poke it through your exhaust port with piston at bdc
bdc.
Rotate crank until it is stopped by the feeler gauge and write down how far it is from tdc (should be around 90 degrees on your kit)
Rotate crank in opposite direction until it is stopped by the feeler gauge.
Write this number down, it should be the same as the first number if you've marked tdc correctly)
Add the 2 numbers together and that is your exhaust duration.
Do the same process for your transfers
Don't bother with your inlet as you've got a reed so it's irrelevant.
I think that's it but I'm fairly confident that someone will spot a mistake somewhere.
Postby Donnie » Fri Sep 11, 2015 6:38 pm
Well ive used the scooterotica calculator here http://scooterotica.net/page19.htm
So, it's a 58 stroke and 107 conrod in there and a deck height of -0.3mm assuming you measure the edge of the crown to deck as opposed to the highest point of the piston crown?
So exhaust port wise im getting 36mm from top of the exhaust port to the top of cylinder giving me 166.73 degrees of exhaust duration
Transfer duration works as 47.45mm top of transfer to top of cylinder giving 113.14 degrees
Inlet duration? Piston skirt length (edge of crown to bottom of piston skirt on inlet side) is 63.06mm however there's a cutout where i have measured it and there's about 3mm either side of this still which is technically the bottom of the piston so hope i measured the correct part? Inlet Floor Depth (Top of Cylinder to Bottom of Inlet Port) is 98mm
anyway if correct the inlet duration is working out at 174.04mm
Donnie
Postby Captain Pugwash » Fri Sep 11, 2015 7:15 pm
Port measurements with a vernier gauge then Re-calculated into degrees is good and it will give you an idea of what port timings your running but the degree disc method mentioned above, will be more accurate and will give you your actual or at the least it will be close to your real port timings, With less chance of errors.
IMO The inlet port duration isn't too critical with the reed fitted but a larger than standard port timing duration and area may be beneficial........
But if the inlet is too wide and doesn't support the piston it can damage the piston skirt.
Captain Pugwash
Postby dickie » Fri Sep 11, 2015 7:42 pm
Donnie, those durations confirm what I expected. Your exhaust should be 173 and 124 for your transfers.
Raising the barrel by 2mm will get you to approximately that. You could easily check by adjusting the numbers you put in the calculator by 2mm, but I'll bet my left gonad that you're within 2 degrees when you add a 2mm base packer.
My wife says I should go out more.
Postby Donnie » Fri Sep 11, 2015 8:28 pm
its funny, i read that the timing disc method was less accurate than measuring lol, ill try the timing disc version tomorrow evening and report back.
thanks all for your patience so far.
Donnie
Postby dickie » Fri Sep 11, 2015 8:42 pm
Timing disc is the daddy. You're measuring directly rather than working back from data.
Direct measurement is always best.
Postby CHRIS in MARGATE » Fri Sep 11, 2015 10:02 pm
Not necessary !
Postby Donnie » Sat Sep 12, 2015 9:25 am
ooops sorry didn't mean to cause problems/rows :?
Donnie
Postby dickie » Sat Sep 12, 2015 9:41 am
Jesus christ Donnie!
This isn't tiddly winks we're talking about here. Don't you understand how deeply the appreciation of port timings on old shopping mopeds can affect all of our futures?
Please think before you ask such flippant questions in future.
Postby rossclark » Sat Sep 12, 2015 1:37 pm
In the interest of balance this one might not cause such a stooshie...
Postby Donnie » Sat Sep 12, 2015 7:15 pm
dickie wrote:Jesus christ Donnie!
LOL
Donnie
Postby Donnie » Sun Sep 13, 2015 7:07 pm
OK so, (moving on :oops: )
Using the timing disc method
the exhaust port is 93 + 93 meaning the exhaust duration's 186 degrees.
Transfers are 117 +117 = 234 degrees??
What have I done wrong???
Donnie
Postby dickie » Sun Sep 13, 2015 8:02 pm
You're 180 degrees out
So, your timings are :
180-93=87
87+87=174 for exhaust
180-117=63
63+63=126 for transfers
These are pretty much spot on for a gt186
Did you get these timings with any base packers or gaskets in place?
Postby Donnie » Sun Sep 13, 2015 8:58 pm
Doh, told you all this was new to me!
Yes, only one standard paper type base gasket in place with this, should I have done it with none?
Donnie
Postby dickie » Sun Sep 13, 2015 11:05 pm
No, you need to understand what they are when you're finished building. So you've done the right thing.
Now you need to check your squish but i guess when you did it originally it was no different to how it is now. Yes?
Am I right in thinking that at tdc the piston crown is 0.3mm above the top of the barrel?
Postby Donnie » Sun Sep 13, 2015 11:27 pm
yes the edge of the crown's .3mm above the barrel top, if I put the head straight on now it'll hit like before. putting the 1mm head gasket only gave me a .5 squish.
Donnie
Postby dickie » Sun Sep 13, 2015 11:40 pm
This is odd. It seems as though you have a short barrel! I know I said it was the less likely scenario earlier!
Double checking, at bdc, is the edge of the piston crown perfectly level with the bottom of the exhaust and transfer ports?
Postby rossclark » Sun Sep 13, 2015 11:50 pm
What type of casing is it?
There is some variability in the height of the base gasket face between Italian / Spanish /Indian cases, though usually it's too high in the latter examples.
Postby Donnie » Thu Sep 17, 2015 12:59 pm
dickie wrote:This is odd. It seems as though you have a short barrel! I know I said it was the less likely scenario earlier!
Sorry for the delay just finished another 3 long shifts but am off for 8 days now :D
Right, just gone out and had a look and no, it's not level, I would estimate the crown sits lower than the bottom edge of the exhaust port by 0.75mm and below both transfers about 1.5mm.
I've been told by the previous owner that the exhaust port has been tickled with which could explain the difference.
Donnie
Users browsing this forum: No registered users and 49 guests
