davla wrote:Personally I found that fitting a new reflector with a standard 12v bulb gave better results than LED bulbs....only my experience though, there may be better LED bulbs out there these days.
coaster wrote:I run full DC systems on both my scoots, one (Series 80 Jet) has a BGM led light board which has been in there without issue for about 6k miles. The other (LiS) has one of these in it http://www.ebay.co.uk/itm/MOTORCYCLE-28 ... 3ceb4b713d
If you remove the red lens, the light board inside lifts out and is a snug fit inside a series 3 lamp unit with the reflector removed. On DC at least, it works a treat, even has a number plate light built in
