Toddy wrote:No the Drilling allows more air into the system, not usually done for a standard scooter but more if an engine upgrade / larger carb has been added , your call re using it depends what engine you are running as to whether you need it drilled .
hullygully wrote:you can still run your airbox & carb as is with your 225 or your Rapido upgrade, but keep an eye on your plug colour, as you'd probably need to keep an keen eye on your pilot & main jets
hullygully wrote:jets wise - alter to suit your engine, carb, exhaust, kit, check plug colour thru' the rev ranges a must!!!!!
compression ratio etc... I know AF's do 2 x types of heads for 225's, higher & slightly lower compression ratio's, plus you'll need to check the piston/head squish clearance of 1.1mm -1.5mm, another must with todays fuels!!!!
Egee wrote:hullygully wrote:jets wise - alter to suit your engine, carb, exhaust, kit, check plug colour thru' the rev ranges a must!!!!!
Not a walk in the park then!
dickie wrote:Egee wrote:hullygully wrote:jets wise - alter to suit your engine, carb, exhaust, kit, check plug colour thru' the rev ranges a must!!!!!
Relax egee. Buy sticky's, read it. Read mb tech site set up instructions. Build your engine sloooowly and methodically. It's just like following a recipe but a little bit more manly.
I'd never even changed a tyre on a lambretta this time last year but I read and read, asked what may or may not be silly questions. I did some stuff, and redid some of the stuff I did wrong but it's all part of the fun.
Just take your time and be thorough and you'll end up with a lovely motor.
It's waited 40 years so I don't think there's any need to start rushing now. Or maybe after 40 years the reaper is your main concern
hullygully wrote:as Dickie said, take your time but try & use as many of your original componants (bearings, seals & gaskets aside) as possible, or be careful which Indibum parts you use!!!![]()
try also to use as many cosher tools as possible too, cos it'll only end in tears, or a chisel/screwdriver embedded in the garage walls
CHRIS in MARGATE wrote:You don't need them all. Start with a flywheel extractor and flywheel holder; and a clutch compressor.
martyn dwane wrote:never used a fork spring compressor, i use a large ring spanner , easy job.
hullygully wrote:I think his first call for help was regarding a SX 200, so he'll need the compression tool
where in the country are you?
