Unknown Tool
Unknown Tool
Postby Dimitrios_231 » Wed Sep 02, 2015 8:15 am
I've searched the official Lambretta workshop tools list,this one is not listed,in fact all the original tools have codes with 5 digits only.
Does anyone have any idea what kind of use this tool could have in the Lambretta world?
I found it inside a pack of original workshop tools.
Dimitrios_231
Re: Unknown Tool
Postby kennystag » Wed Sep 02, 2015 10:35 am
Hi,
It is a bearing or hub puller.
Stag
kennystag
Re: Unknown Tool
Postby coaster » Wed Sep 02, 2015 10:39 am
kennystag wrote:Hi,
Stag
I was thinking the same, crank inner race removal??
colin
Re: Unknown Tool
Postby Adam_Winstone » Wed Sep 02, 2015 1:00 pm
Non Lambretta generic bearing puller?
Re: Unknown Tool
Postby Dimitrios_231 » Wed Sep 02, 2015 1:11 pm
Adam_Winstone wrote:Non Lambretta generic bearing puller?
Probably ;)
coaster wrote:
kennystag wrote:Hi,
Stag
colin
Not long enough,
I have another longer generic that could be used for the crank inner,plus the original workshop tool.
Thank you guys,it can be a Vethpa tool as the guy that I took it from was also building scooters from the other brand :)
Dimitrios_231
Re: Unknown Tool
Postby hullygully » Wed Sep 02, 2015 1:36 pm
is it an early clutch spider remover? :shock:
Re: Unknown Tool
Postby Tractorman » Wed Sep 02, 2015 2:54 pm
It could be for an earlier model Lambretta. The legs near the jaw is specially shaped to fit something, maybe a gear or plate. It's also be 'modified' for use on something else.
Re: Unknown Tool
Postby Dimitrios_231 » Wed Sep 02, 2015 3:15 pm
Thank you again guys :D ,
it must not be a Lambretta tool all the official codes are with 5 digits.
hullygully wrote:is it an early clutch spider remover? :shock:
The code is 78013 :(
This is the price list from a large selection of original workshop tools,
I found it on an Italian scooter forum.
Dimitrios_231
Re: Unknown Tool
Postby Dimitrios_231 » Wed Sep 02, 2015 7:17 pm
Just took two pics to show,
the original workshop tool for the crank inner race removal left,a generic puller at the middle and the unknown generic puller right.
Dimitrios_231
Re: Unknown Tool
Postby rossclark » Wed Sep 02, 2015 10:49 pm
Would it fit between the two rows of teeth on a front sprocket?
Re: Unknown Tool
Postby Dimitrios_231 » Thu Sep 03, 2015 1:14 pm
It fits between the two rows of 14T and 15T front sprockets but it cannot be used as an extractor because it is too short.
I've searched on the web and found that this kind of tool is called Pitman Arm Puller,
I don't know if it can have any use on 3 wheelers.
15T
16T
19T
15T
18T
Dimitrios_231
Users browsing this forum: No registered users and 90 guests
