Not seen this before!!
Postby Vega125s » Tue Sep 01, 2015 2:49 pm
This is my 5 plate aprilia clutch. I presume it was an interference fit.
Do you think this can be glued using the proper loctite or should i weld it or chuck it ?
cheers.
Vega125s
Re: Not seen this before!!
Postby Donnie » Tue Sep 01, 2015 4:27 pm
Personally I'd chuck it.
Donnie
Postby Warkton Tornado No.1 » Wed Sep 02, 2015 1:28 am
I've seen this happen, often with remade clutch sprockets.
Measure the bore & bush with something that will give you an accurate idea of the clearance. You can always press the bush out of an old knackered sprocket & check that. A vice is often adequate for the job.
If Loctite or any other good product can cope with the clearance, try it, keep an eye on it.
It's not a stressed component as in taking load from bush to teeth. All the work is done via the castellations.
Postby Vega125s » Thu Sep 03, 2015 8:56 pm
Thankyou for the info,
Although there is a specific loctite [648] designed for interference fits like this I'm going to have it weld just to make sure.
cheers
Vega125s
