daniel whiteley wrote:As title says I'm wondering which one to buy out of these 2 , I'm upgrading all components bearings seals crank ect but I can't decide which one of these kits to fit , I'm after more power and reliability than my standard engine which is a 125 special it's going to be used for general running around with the odd 2 up with either the Mrs or one of the kids doesn't have to be rocket fast just reliable , I know it's been asked before but they have been around for a while and would like a fresh response to help me decide pros and cons and such
martin1310 wrote:both of them are good kits i run both of them very similar power out of the box
also i have both kits in stock if you need a price pm me
thanks martin
daniel whiteley wrote:martin1310 wrote:both of them are good kits i run both of them very similar power out of the box
thanks martin
Thanks for the reply , you run them both so which in your opinion is
A... Better quality produced/made
B... Most reliable
C... Most powerful with same set up of carb ,crank ,exhaust
D... Best fit with engine, exhaust ,cowls
E... Best in cost efficiency for running/buying
TS1-200 wrote:Go for the RT kit with 60 x 110 crank
