Play between Hub and fork link
Postby Covboy » Wed Aug 26, 2015 2:58 pm
Hi all
On my S2 L1150 there is about 3 mm of play between the fork link stub and the hub - is this safe / normal? Should the fit be tight?
The hub "slot" does not look worn and the fork link the original which is visually OK / not worn either..
Re: Play between Hub and fork link
Postby grandpa » Wed Aug 26, 2015 5:13 pm
Hi Cov,boy.
There was some play on my indian between hub and fork link.I used a strip of rubber from an inner tube wrapped around the stud when I fitted wheel.
Grandpa
grandpa
Postby Covboy » Wed Aug 26, 2015 5:19 pm
Thank you- I will do the same...
Postby Triffid » Wed Aug 26, 2015 8:32 pm
I use a strip of insulating insulating tape wrapped around the peg on the fork link so that there is a nice tight fit between it and the slot on the hub backplate :)
Triffid
Postby zugbug » Wed Aug 26, 2015 11:23 pm
Thanks guys you just helped me to fix my problem too, I thought the headset was loose due to the knocking sensation but after slackening off the front brake I noticed that the link pin was moving a tiny amount in the slot, thanks to your tips I can sort it for the MOT :D
zugbug
Postby HxPaul » Thu Aug 27, 2015 9:30 am
I have a series 2 and the hub doesn't knock,but a friend of mine has a Spanish silver special and to get rid of the play and the knocking it caused he cut a peice of copper pipe,the ones that plumbers use and squashed it to an oval and fit it in the slot in the hub,the peg on the link fits snuggly in the pipe - no knocking.
Postby Covboy » Thu Aug 27, 2015 11:25 am
Thanks Guys - all good suggestions - I think i'll try the copper pipe one..... :D
