Hughieboy wrote:I guess that would be simplest.... But I wonder how long it would work for between charges, ie minutes or hours...? I have a trickle charge, would you think an over night plug into that would be enough to keep it usable?
coaster wrote:Hughieboy wrote:I guess that would be simplest.... But I wonder how long it would work for between charges, ie minutes or hours...? I have a trickle charge, would you think an over night plug into that would be enough to keep it usable?
Terry's is correct' there isn't enough power from any of the conventional magnetos (including the Varitronic) to power a spot of any practical use. Your idea of powering one from a battery is fine though and to keep it simple I would use a 7 amph alarm type battery. That will give you an hour or 2 use between charging on a battery charger. You might be able to get away with a smaller battery, maybe around 4 Amph and you could charge it on the scooter via a simple Mod charger. That would provide a trickle charge that might even be enough to keep the battery charged without resorting to the mains charger. That would depend on how much riding you do without the spot though.
All that said though, if you live in the sticks and ride at night then I would strongly advocate a full DC conversion, it really isn't't complicated, my set allows me to run an HID headlamp and 2 LED spots and the result and light output has to be seen to be believed.
grandpa wrote:Hi Hughieboy,
You can get universal plastic chrome Harley spots from ebay with a 10 watt led bulb and 27 leds ( about £12 ebay delivered from china)using watts =volts X amps would give you 4 hours on a 5 amp/hr battery.(10 /12 =1.2 amps) I am not sure about the MOT as usually the spot can only run on main beam.The wassell mod with a battery would enable spots via a relay thus:
The leds run from festoon bulb and centre spots from main beam via a small relay
Grandpa
terryj wrote:have seen a post on ere somewhere were the battery was fitted in a box on the rear mud guard
Hughieboy wrote:Thanks Guys,
That's great helpful info...
The scooter is a S2 so assuming the Jockeys headlamp reflector is available for it that sounds like a great way to improve the headlamp. I'm currently running one of those HID bulbs but in the standard headlamp reflector/lens unit so it's brighter but the spread isn't great and the difference between dip and main seems negligible.
coaster wrote:Hughieboy wrote:Thanks Guys,
That will be an LED lamp of Halogen not a real HID. You need DC and a battery for HID to work. They are not like a conventional lamp, there is no filament, the light is created by an arc and is powered by a 'ballast' unit that kicks out something like 30k volts. Dip is effected by a small solenoid built into the base which moved the lamp up and down. The photos above don't really do it justice, they were taken on a country lane in the wilds of Norfolk with open fields on either side and the HID light spreads way out sideways as well. Looking at the photos you can see a road sign lit up in the background on both of them.... That sign was around 1/4 of a mile away
as for doing the wassel i am a complete idiot when it comes to electrickery and i found it a doddle
change 1 wire of the stator join up wassel and wassell to brown in loom and fit battery job done
Users browsing this forum: No registered users and 203 guests
