Flooding Carb & Massive Spit Back
Postby Granty » Sat Aug 22, 2015 6:47 pm
Guys -- running the 30mm delly today & changed the atomiser down. stupidly left the chock on & ran it for about 1/2 mile before I realised -- I've changed the atomiser back to the meaner one but the engine will not tick over and the spit back out the carb is horrendous -- any ideas before I chuck it through a window.
could something just be stuck?
Granty
Re: Flooding Carb & Massive Spit Back
Postby Cgt75b » Sat Aug 22, 2015 7:15 pm
Yeah the choke.
Postby Granty » Mon Aug 24, 2015 6:57 pm
Carb stripped today - nothing seems to be stuck and defo not the choke -- but here's the strange bit.
On a wee ride today everything going great up to 1/4 throttle and then up to 1/2 throttle. When I opened it up to 3/4 - full throttle scoot running well for a bit then when I rolled the throttle back it felt like the carb was flooded and it just wouldn't rev at all and really boggy. Left the bike for 10 mins, started it and ran well again at 1/4 throttle home again -- anyone had this before and any ideas? - G
Granty
Postby CHRIS in MARGATE » Mon Aug 24, 2015 7:24 pm
Have you got some of air filter on there? If so, you'll have to remove it.
Postby Granty » Mon Aug 24, 2015 7:54 pm
CHRIS in MARGATE wrote:Have you got some of air filter on there? If so, you'll have to remove it.
Open mouth carb Chris -- absolutely crazy -- goes OK up the throttle but bogs down something horrendous on the way back down -- G
Granty
Postby Rich Oswald » Tue Aug 25, 2015 3:29 pm
Have a check to see if your clip on the needle has moved or even come off?
Postby Granty » Tue Aug 25, 2015 5:14 pm
Rich Oswald wrote:Have a check to see if your clip on the needle has moved or even come off?
Hi Rich -- checked that last night and clip is still in place 2nd from the top --- now going to replace the atomiser with a new one just in case the old one has been modified in any way. its the strangest thing -- up to 1/4 throttle all is well, up to 1/2 throttle a bit boggy, on 3/4 throttle goes well but then it feels like someone has just chucked a load of petrol in the carb and it floods on the way back down.
Granty
Postby Warkton Tornado No.1 » Wed Aug 26, 2015 5:44 am
I presume this is a PHBH 30 mm.
Your symptons sound like you have the needle moving out of 'register' with the slide, alright on the way up, sticking on the way down. But how?
Although you say the "clip is still in place 2nd from the top" have you ensured it is under the needle retaining plate & not above it?
It would be an easy mistake to make.
Postby Granty » Wed Aug 26, 2015 8:01 am
Warkton Tornado No.1 wrote:I presume this is a PHBH 30 mm.
You know what, I think that's the ball game right there, I'm sure the needle clip is above the retaining plate on the spring side rather than underneath the plate, this would mean that it's coming up with the slide but is "floating" on the way back down. Up to the man cave tonight I guess.
Granty
Postby hullygully » Wed Aug 26, 2015 12:16 pm
good job you went in car to hand those stickers out on saturday :lol: :lol:
Postby Rich Oswald » Wed Aug 26, 2015 12:22 pm
hullygully wrote:good job you went in car to hand those stickers out on saturday :lol: :lol:
Postby Paulnobodyimportant » Wed Aug 26, 2015 12:41 pm
Oh dear, that explains a lot. For the last 8 years, I have been sitting the needle clip on top of the plate and often wondered how it sorted its self out when dropping off the revs. Just checked a few Dellorto diagrams and you are correct and it all makes sense.
Here to some happy jetting at last.
Many thanks from a grateful Dork
Paulnobodyimportant
Postby Granty » Wed Aug 26, 2015 1:59 pm
Wrong Granty Buddy -- this one is from the ELSC Chapter -- G :D
Granty
Postby Warkton Tornado No.1 » Wed Aug 26, 2015 9:33 pm
Remember that if your jetting was anything like correct with the clip above the plate, you need to move the clip to a groove below & possibly more. You can fiddle to get fairly close with the shims that we all should have. I know I have some, it's finding them that is the problem....
Postby Granty » Wed Aug 26, 2015 9:44 pm
Warkton Tornado No.1 wrote:Remember that if your jetting was anything like correct with the clip above the plate, you need to move the clip to a groove below & possibly more. You can fiddle to get fairly close with the shims that we all should have. I know I have some, it's finding them that is the problem....
Many thanks for your help, the clip was the issue, now I have the clip in the right place and all well, can't thank you enough. Jetting scheduled for Friday afternoon with more jets, atomisers you can shake a stick at, currently have the set up below
30mm delly open mouthed
42mm Clubman
Stage 4 200 lump
50 pilot
40 slide (a wee bit worn)
AV266 needle jet
X7 needle clip 2nd from top
125 main jet
Let's see what Friday brings -- hahaha
Granty
Postby Toddy » Thu Aug 27, 2015 6:07 am
Postby Paulnobodyimportant » Thu Aug 27, 2015 9:07 am
Yes, I did think that and will look at 2 of my lambretta's tomorrow. It all makes sense and I don't know if over the years I made a quantum leap to place the needle clip on top of the plate, as both scooters have been dynoed in the past.
But it does now explain why I am struggling to jet in my tuned monza up to half revs and getting random 4 stroking; the needles not dropping down to the right place, (30PHBH). The other one is a TS1 with a TMX35, so I will have a look at that and see if the needle clip is located correctly as it does seem erratic when dropping down to low revs.
Phew, here's looking forward to some smoother riding and easier jetting in.
Paulnobodyimportant
Postby hullygully » Thu Aug 27, 2015 11:32 am
sozzzzzzzzzz :oops: it was ste-veg :roll: :lol:
Return to Carburettors
Users browsing this forum: No registered users and 0 guests
