by Raveydavey » Fri Aug 21, 2015 4:16 pm
If I tighten the nut up to 'very' tight the clutch bell seems to have some mild resistance, meaning its tightened down on the bearing. Slacken it just a tiny bit and its fine. Am i missing something?
Raveydavey
by Wack » Fri Aug 21, 2015 5:46 pm
Sounds like it's trapping the crownwheel and making it hard to turn. If you remove the crownwheel then refit the spider and tighten it will prove it or otherwise.
by Raveydavey » Fri Aug 21, 2015 6:19 pm
Good thinking, Wack. I'll try that. Cheers
Raveydavey
by Raveydavey » Sat Aug 22, 2015 1:25 pm
For the record, it was absolutely that. Had to fettle a shim to give a bit of clearance. All good now.
Sometimes the obvious just doesn't make itself known
Raveydavey
Users browsing this forum: No registered users and 218 guests
