26mm Delly PHB
26mm Delly PHB
Postby hullygully » Fri Aug 21, 2015 9:23 am
What manifolds for a 26mm Delly, breathing thro' the std airbox & 22mm rubber, & still wearing un-cut side cans, are you all using?
I'm using a Beedy 90 deg type one & it pushes the carb rubber out so it gets compressed by the side can :evil: & its restricting the air-flow :(
So before I start stripping I'm seeking your advice?
Re: 26mm Delly PHB
Postby Donnie » Fri Aug 21, 2015 8:35 pm
You cant use a standard airbox with a 26phbh
Donnie
Re: 26mm Delly PHB
Postby hullygully » Mon Aug 24, 2015 10:44 am
well I am................. & its running fine ;) the air box is empty & drilled
there's no scope to pull back 20mm from the Beedy 90deg manifold, so I'm asking has anyone used a Jimmers type manifold in this situ, or machined a downdrafty type one to suit, or used radiator hose instead of carb rubbers to pull the 20 mm back needed to have the side cans on? :shock:
are the plastic float chambers shallower than the cast alloy ones as that fouls the TV's head cowl air scoop too!!! :evil:
Re: 26mm Delly PHB
Postby bolzenanker » Mon Aug 24, 2015 12:25 pm
Hully
I've got an RLC Maxi Flusso manifold spare which is supposed to be used with the airbox and a rubber mount PHBH. In my case it fouled the frame.
I'll happily post it to you to experiment with if you like?
Warren
bolzenanker
Re: 26mm Delly PHB
Postby hullygully » Tue Aug 25, 2015 11:44 am
cheers Warren P.M. sent
RichKTMH, I think you gave me a wobbler with the difference in float chambers, as the 25mm's floats are pivotted whilst the 26mm's slide up & down matey like the large Dellies
Re: 26mm Delly PHB
Postby Rich Oswald » Tue Aug 25, 2015 3:26 pm
hullygully wrote:cheers Warren P.M. sent
:lol: :lol: :lol: Calm down Mickey, lol.
Re: 26mm Delly PHB
Postby hullygully » Tue Sep 01, 2015 10:50 am
deep breaths Rich :lol:
took the long Mallossi UK/V**pa :o carb rubber off & replaced with the main man Broady's MBD/Racetour carb rubber, that's 10mm shorter, even tho' the float chamber touches the TV cowling's air scoop, @ least I can now ride with it's side cans on 8-) without any carb breathing probs ;) RESULT :D
Return to Carburettors
