by JBG584 » Sun Aug 16, 2015 7:15 pm
Hi
pins on my flywheel on series2 have come forward and jammed motor have got flywheel, of can the pins be replaced if they can be removed or does it mean another flywheel
Ray
JBG584
by Wack » Sun Aug 16, 2015 7:50 pm
Use M5 tensile bolts ,washers and locknuts to fasten the boss to the flywheel.
by JBG584 » Sun Aug 16, 2015 11:50 pm
Hi Thanks but not the boss but the outer ring joining fan to flywheel
JBG584
by Jim Rose » Mon Aug 17, 2015 10:08 am
I've had that happen a long time ago. It's a fairly common problem with the two piece flywheels. I tried some bodge repairs but gave up. I actually fitted a washing machine fan onto the brass; which was a popular modification in thye 80's.I'd get another flywheel if I were you.
Jim Rose
by Adam_Winstone » Mon Aug 17, 2015 4:59 pm
All too common a failure point, one that I recently mentioned on another thread.
I've had 1 fail, which I cured by drilling, tapping and bolting the 2 together... and another which came to me already loose, which I bolted a nylon fan too (as described above).
I'd have to think twice about simply fitting another unmodified flywheel of the same type.
Adam
by JBG584 » Mon Aug 17, 2015 8:06 pm
Thanks Adam and others.
think I might try drilling and tapping then loctite screw in
JBG584
by steve c » Fri Aug 21, 2015 10:26 am
ray drill and tap and countersink the fan, use m5 countersunk high tensile screws not stainless or unknown, two Allen screw M5 by 12mm should do it but put them 180 degrees opposite to keep the flywheel balance,
steve
steve c
by Digger » Fri Aug 21, 2015 10:33 am
I had one go in 1980 - Araldite sorted it.
Digger
Users browsing this forum: No registered users and 209 guests
