Donnie wrote:Carb mate, I'd put money on it. Yes I know you are going to say you replaced the carb for another one, but unfortunately you also said it was set up exactly the same.
So, I'd say there's an issue with either the atomiser or the needle personally.
Wack wrote:The AF cranks are known to twist which could knock the ignition out at certain revs? Have you checked out the loom and ignition switch and that the throttle pulley is not catching any wiring?
torquewrench wrote:Before you head over to the lake….![]()
If everything mechanical and electrical has been checked and is O.K., and the problem seems to be linked to throttle position, have you considered that fuel starvation might be the issue ?
If so, could it be as simple as a blocked breather in the filler cap, which is impacting your fuel flow rate at higher revs ?
cobby56 wrote:Lakes still tempting![]()
JETEX wrote:Have you tried running it with the headset top off ?. As said previously, if it's happening at the same throttle position, it could be that the throttle roller is pinching the wiring in a certain position ?
JETEX wrote:I was thinking along the lines of the throttle roller hitting the green wire, thus shorting it out perhaps ?. You know the thing, straws, clutching, at ( re-arrange ) !
